S.A.B.
Hi, I have a probably trivial problem.
I must create the model of a keychain, a simple parallelepiped with an embossed writing; the problem is that the writing must be connected with the base through a bevel, and I do not know/not know how to use the proper command.
if I use the command "smussa surfaces" the bevel does not follow the profile of the letter, it touches me to bevel one side at a time and in the end I can not join the bevels with the polysurface.
to understand, this is the result I would like to get, but in this case I used the sweep command at 1 track, which is uncomfortable for letters with complex shapes and in the end I can not however make the Boolean union between the bevel and the polysurfaces.
is there a command that allows to obtain the same result easily and to join the bevel to the polysurface?
if I use the command "smussa surfaces" the bevel does not follow the profile of the letter, it touches me to bevel one side at a time and in the end I can not join the bevels with the polysurface.to understand, this is the result I would like to get, but in this case I used the sweep command at 1 track, which is uncomfortable for letters with complex shapes and in the end I can not however make the Boolean union between the bevel and the polysurfaces.
