find them in design. in practical checks on the wall the profile you designed instead of the classic rectangle. the wall then extruded through that section
the shape of the wall I can draw it in the plant and extrude it, but I need it up, if you saw the attachment, that is how I should see it in the prospectus, thank you in advance!!! !
the materials you need to set them directly from the complex profile shovel. using divides you can also make a stratigraphy to which to assign different materials. I would still do a unique object, loft and wall using a single profile
