constraint gear movement created by inventor
  • Thread starter Thread starter ramjet
ramjet
Good morning
I'd like to turn two trees between them orthogonals.
first I created with design accelerator two conical wheels, assigning the appropriate transmission ratio.
I was thus generated the axieme with the two wheels, among them already bound.
I then opened one of the two wheels, creating on it the rest of the tree.
when I go to mount this assembly (i.e. the gear) and impose the bond of movement there is no way to move the two gears and the relative shaft.
Can you tell me where I was wrong?
By the way, if I open the axieme of the two wheels, the constraints (those created by design accelerator) are all frozen and there is no way to eliminate them.
Good morning
try putting the accelerator design axieme into "flexible"
Meanwhile I attach the file as required.
I took the drawing from a drawing book iti. (caligaris, fava tommasello "from project to product" ed. paravia)
the design had the sole purpose of "taking my hand" with inventor, who I haven't used for at least 2 years.
the design is in the attached pdf.
some measures of the parts mentioned in the book do not coincide with those which then lie in the axieme, so sometimes I had to "extend the measurements" (robe of a few millimeters, nothing of which).
Attached you will find the design on which I've been enough and the axieme made with inventor.
the problem is that I can't move the gears (created with accelerator design).
Thanks for the help.
He didn't load me the winzip with the gearbox.
He says it's too big.
8.8 mega zippers.
What do I do? ?
