AlessioOvo
I would like to turn a wing on the left and right until it touches the wing on the central support base. that I must use for this movement.
turn until it touches or on the right or left.like a steering wheel with wheels when it touches the wheel on the one hand no longer. the concept is equal.. .
If I use a single angle then it doesn't even move...I would like to put the side corner on it and then make it rotational in another corner between the wing corner 120° example and 160° maximum angle at 180° touch.cosicche has 30° degrees left to turn and 30° right.
It's a brothel! !
It's a brothel! !
