constraints sketch
  • Thread starter Thread starter magicfazer
magicfazer
recently when I work in the sketch environment I can no longer automatically take the horizontal and vertical ties to the lines I design, have I disabled something? What? Thank you.
are all enabled but if the individual lines are not drawn I give them the horizontal and vertical bond automatically does not recognize them (e.g. drawing a rectangle the individual lines are not horizontal or vertical)
What inventor version do you use?
However there should be an icon near the quota icons or constraints called "deduction bond" you probably deactivated it without wanting.
Well, the question was rhetorical. press f1 and type "deduction bond" in the search box.. .
I'll take the discussion. use inventor 2013. in sketchy environment, if for example insert a point, it does not keep me constraints. I have selected both "constraint persistency" and "deduction constraints" and the bond options I have checked all kinds of constraints.. .
Yes, but what constraints did you break?
Did you check if they're activated?
right click on graphic window -> bond options
bho, mystery.
Does he always do it or a tantum?
for me, for example, he often loses the check on "change share to creation"...., but it is enough to reactivate it.
on the other hand, sometimes the green dot is no longer visible that you are on a snap, in this case there is nothing else to do but reboot the pc
the constraints never kept me! I keep working, but it's an endless break... The green dot of origin disappears every now and then:confused:
I apologize if I repeat this old discussion .. but I would like to understand if I error something or in inventor you can not do .. if I draw a set of points using vertical and horizontal projection are not automatically bound what happens in solid works automatically.
I tried to put vertical and horizontal deduction but it does not work.
deductions are all selected
otherwise try in automatic quotation leaving only the check on the constraints removing that on the quotas
alignment constraints between "points" and only points between them, if I understood correctly, it does not automatically.
you have to create construction lines and bind them to them.
the various deductions you speak of are valid only for lines and cune other forms, but not for single points alone.
