Giacomo1989
good evening to all, I would like to know, how to bind a particular so that after having realized it if I change the quota he does not change?
I'm sorry, but I don't understand.with a couple where the changeable share is not affected
I mean this: If for example I draw a piece and the next day I should change a share of that piece, how do I block the others to avoid changing that share also change the other odds?Actually, you don't understand the meaning of the first question. If I do a piece, I put it together and put it fixed....where should it go? Clearly his geometry changes it....change. to not change a piece, you do not have to make changes. if you want to know how it is best to bind the pieces that can take different shapes is that you can pair them with the main planes between piece and piece.
