panormus
Hey, guys.
I hope someone can help me, lately I feel like writing blank..:frown: Blessed are you who are in holiday:
1) I should make a series of solids, exactly of the wooden alar inches, crossed by longherons.
I should do something like that.
limiting me to create the entire centines and to obtain the perforated centines automatically from the intersection with the longherons.
made the intersections and generated the holes should cut the centin to cnc with its hole.
question: Should I use Boolean operations?
if I had to create this drilling by intersecting 2 products (an auction and a complex product/solid) how should I do?
2) the very prepared ferretium kindly sent me a catpart with the wing profile of the centin realized as geometryfromexcel plus a profile scaled from two profiles (extended and intradox joined to the ends from one point) following a set of points supplied to him, but that I failed to work to generate a solid.
I am at this point: https://docs.google.com/leaf?id=0b-4nj7fcicwmzte2mjiyngitnzdlnc00zjmxltk0yzitnjg5mjm4ndzlywnk&hl=itbasically I can't handle the scaled profile (generated by two profiles, as I said) as it was a sketch to use to generate a prism (to a thickness). Maybe it's not a detail that the body's gear is gray.
Can you help me?
Can you help me?
