graziano-g
design a cylinder on the xy plane then proceed with a new sketch on the zx plane
select construction line then project cutting edges then cut graphics.
result: solid sectioned and lined, all right.
now select symmetry axis and draw a line that goes from the center of the upper face the center of the lower one.
if I remain in perpendicular display on the zx plane and draw the axis as soon as I click on the central point of one of the two lines/cut edges of the sup or inf faces and when I click on the other are added overlapping axis lines.
If to do the operation I move into a perspective view this does not happen and I get the only axis line I need.
ok, is the solution intrinsic however there is a parameter to set to avoid this?
