construction lines
  • Thread starter Thread starter piccio__87
piccio__87
Hello.
banal question but I do not find the command....
How do I figure out the construction lines in the paper mill?
(in the folded model)
Thanks.:biggrin:
What's the paper for you?
for me is the tag where the header, code, description, scale and other similar information is indicated.
You mean something else?
for me too:
I think you have some confusion in your head. .
Anyway click on the view to edit and do "crash", from there draw everything you want, if I understood correctly....
Sorry... my mistake! ! ! ! ! ! !
I saved it with that name in the templates because I have several that differ only in the cartiglio..... came to say so...
is a .idw file!
is the 2d table of the finished piece! ! ! !
inside the .idw file, how do I draw construction lines?
construction lines you can't do, at the limit in the table you can enter the sketch, create the lines by placing them where you want to create the odds, or a nice copy save in dwg and then insert all the lines you want
