cocos84
Hello.
I have two plates one superimposed to the other, each has its built hexa mesh extruding quad elemnti, I would like to create a contact between the two plates as one of the two is loaded while the other is bound as I can create contacts between these two plates? (I do not want to use equivalence as I have two different mesh, and I would like to use a "deformable body" contact). What is the exact procedure that makes me deform the two plates as if they were welded? .
Thank you very much.
