content center and or
  • Thread starter Thread starter HOOPS
HOOPS
Hello everyone, where I can find the complete series of or with its codes
es: or 4118 (d. 29.75x3.53)
Open it - drag the "x" end of the part to the bottom - save - publish (instruments - public part), selections where you want it to be put your part....
edited content center, then go to fix the fields that interest you. . .
but so I have to change it every time.... is there no way to download the complete series??
No, I understand what you mean...
Anyway I was wrong, try to see thesep.s. are i-part, if you try to insert them into a set, varying the key fields, a different part is generated from time to time
I use the regulations as 2842 hydraulic and static tire to know which or corresponds you just have a table (you also find it with google or give it by some supplier of or) of conversion.
found under tree/sealing parts
in your case you will have to enter the n° 217(column designation) of that legislation.
