ocraM999
hello to all
I have a problem with revit 2014 (update release 1).
I'm designing continuous facades. I created a type of façade with only fixed-distance vertical mountings. then manually add one horizontal to the desired height. inside the facade I need to insert some openings and here problems begin.
until yesterday I was able to select the vertical mounts and their grids, so I erased those that I needed and then switch the panels into openings.
from today, even with tab, I can no longer select the individual elements. If they select the facade, or select the whole system, or select the grids but all in block, then I can't select them individually.
specific that since yesterday I have not installed updates of any kind, nor so much made changes to the type of family.
I also tried to create a new file from the default revit template... Same problem.
Finally I noticed that the mounts and grills put manually are selectable or deleteable, while those automatically placed according to the facade system remain unselectable.
What can that be? is it a bug or is there a general setting that blocks my changes?
I thank you in advance.
