continuous glazed facade panel, change color
  • Thread starter Thread starter xcel2005it
xcel2005it
Hello.
I have a question to ask you.
I have created a continuous facade panel----colored glass panel div. horizontal; clicking on element property----change type----continuous facade panel I would like to change from blue glass system panel to another color glass panel that nn is available.
how do I create system glass panels of other colors?
or
how do I create a glass panel of other color without going to assign the color from time to time from the rendering engine?
I hope to have explained :biggrin:
thanks for suggestions
you have created a new type of continuous facade not a new panel.
do so:
draws the continuous facade
select a panel>modification type>duplica
assign a name to the new panel
assigns a new material to the panel.
select the continuous facade>change type>in facade panel continue choose the type you have just created.
do so:
perfect, problem solved! !
precise, simple and quick description
Thank you! :finger:
