giacominolonghi
hello to all, I am a designer geometra and designer, use autocad map 2014 and I would like to report to you a problem that I respond very often using oil program: at the time of canceling or repeating a certain command (classic buttons with darts), it takes me a century to return to the previous command or to cancel the modification just made.... I explain better... We put for example that I am working in a catastral map, I gate a line and do not zoom after the cancellation, I go to cancel the command and I have to clikkarlo at least a dozen times to return a simple command just executed. Even worse if I zoomed out more after giving commands... in that case I happened to get to triple the number of times when I have to clikkate the button cancels.
I would kindly ask and understand through some of your advice the problem, understand if it depends on every single file or if it is a general problem id autocad, as not with all the files this disguido happens.
I tried to restart autocad, restart the computer, rename or overwrite the files in question, or to cancel a group of commands to return faster to the graphic and design situation before the modification to be cancelled, but in essence the resolution of the problem is momentary since as soon as I need to cancel a following command, I again miss the great time and clikkare thousand times the button cancels. other particularity is that even in the settings, under "tools-options-preferences-user" I have popped both "nothing/repeti" options by activating them, but nothing to do.
jacomo
jacomo
