Good morning
please tell me how to make the outline of a detail view invisible (see image), I would like not to make it appear in the table
use nx12
I believe that the previous answer is not the correct one because the detail was done, if I do not go wrong, through view boundary.
if it is as I imagine you have to use the view dependent edit > select the view, edit entire objects > put line style invisible > apply and then select the lines.
Good morning
excuse the delay for the answer but I tried several times because I did not understand that the result is visible only on the printed pdf.
yes my view was hidden from a boundary- break line/detail,
In any case, both answers have come back useful
Thanks again
Good morning.
I add a probable solution.
"if" the break line was created inside the sketch of the view then you can simply turn off that sketch, you find it embedded in the view in the part navigator.
