control of hole diameter
  • Thread starter Thread starter stefanoma
stefanoma
I think it happened to many designers to send plates and brackets into production and that maybe a m6 hole and the 5 hole pass. the good climbers can make up soon, the harder to pass a hole from big to small. Fortunately, they result in a remedy. I ask you unlike the interassis where you can immediately verify the error if the piece is coupled hole / hole if esite a method or a macro in solidworks where it is possible to make also a control of the size of the holes in automatic. thanks to all and good forums.
if the request is of solidworks perhaps open the discussion in the appropriate section would be preferable. you also do a research to see if the topic has already been treated and if in subsection resources there is macro
I've been thinking about this for a while. it would be really useful in the environment of assembly, but also of multibody, that the command of the hole considered both the hole of passage screw and the threaded hole as connected. a lot of mistakes would be avoided and the commands would be very thin
