control
  • Thread starter Thread starter simlaz
simlaz
Hello everyone
I need to understand how nx interference control works.
Can you give me directions?
Please
Well, boy, what are you complaining about?
You put a "good" so yelled that everyone felt a bit uncomfortable, you don't think
:36_1_12:
I would start by reading the help and then I would go over here on the forum as I did not understand
I didn't want to be rude.
I tried to launch the analysis on all the assembling with all the components against everyone and the "does not make it"...out of memory".
I am reading the guide calmly to understand how to improve the analysis perhaps by making progressive steps.
I have another problem... we have prepared the standad part of the screws with nominal diameter that goes therefore in interference with all the threads....how can I do? exclude the screws doesn't seem a good idea because I would risk entering a screw without making the thread and I wouldn't notice it. and change all the screws to bring the diameter to the size of the foreskin seems exaggerated and expensive in terms of time.
suggestions?
Even the option that creates you all the interfering solids fails?
With that, you'd have an eye on him.
1) the solids of the interference of the screws resulting from the tubular (and you can eliminate them )
2) the solids of the interference of the vines as diameters and you understand that you did not make the hole
3) other solids and go to alarm
Strange that I go out of memory, what amount of axioms are we talking about?
I tried to launch the analysis straight from the total axieme of the mold, so it is over a thousand components of which a large number are screws that of course - as mentioned - are all in interference.
What advice do you give me on how to conduct the analysis?
Well if it is a matter of quantity of components to be analyzed and the system exhausts the ram, in addition to the usual controls on the available ram quantities, also on the windows swap file,
I would say to isolate a mold area and check on that and then switch to the others.
perhaps closing in the axieme as not secessary
I'm not coming out.
I tried to launch the analysis on half mold - fixed side - and I also excluded all the screws, which would inevitably give me interference.
result... after a little "grip" nx closes me brutally!
and precise...the selected components were only 150...they don't seem many
:confused:
