conversion edwr
  • Thread starter Thread starter tripfabio
tripfabio
I have a problem, I have a edwr file that seems to me to understand it is possible to open it with solidworks, someone could convert me to a step or dwg file so that you can read it on inventor?
if you do not attach the file surely you can not convert anything a priori.
However edrw is an openable drawing file with edrawing solidworks reading software. is a drawing board format comparable to a pdf. you cannot export anything
an edrawing does not contain solid geometry and cannot be converted into step or other solid formats. you can only view it with edrawing. there should only be an option that allows you to export it to stl, but with a stl you do very little, unless you start rebuilding it with a reverse engineering software.
