titor
maybe I didn't use the "search" function at best, but I didn't find a solution to the following problem:
(ctb-->stb) fixes the question of converting a .dwg file thought with .ctb print styles into its .dwg file with the .stb equivalent (comandi convertpstyles and convertctb),
(stb-->ctb) I now have the known need for the .dwg file thought in .stb with its .stb file to have the same .dwg file and the corresponding .ctb file created from the .stb file
I fear that this is not possible, in the sense that I convert the dwg so that you work with .ctb (convertpstyles), but the corresponding .ctb I have to recreate it by hand without possibility of automatic conversion?
thanks for your attention greetings
