Furnu87
Good day to all.
I designed a funnel using the revolution function. the imbute has a upper cylinder of 30 mm high ø240, a lower cylinder with ø110 and height 30 mm, connected between larus by a cone section. I then emptied it with 2 mm thickness.
I would now need to develop and then I would like to convert it into sheet metal. How do you do with the "sheet converts" command? what parameters I have to give. With the plates, I'm not very experienced. . .
Thank you in advance.
enrico
enrico
