conversion of .stl files
  • Thread starter Thread starter gianky73
gianky73
hi, would like to know if you can open with pro/engineer a .stl file and convert it to .prt
thanks and 1 greeting to all
the stl format insert it as facet feature if you have the rex module.
is a triangular data file used for stereolithography (fast protection) and reverse engineering.
you cannot transform it into parasolid, it does not contain solid surfaces or entities.
It is usually seen by solidworks as a graphic entity.
Is it a complex piece?
It is an implant component for dental prostheses. . .
is there any way or software to convert qst .stl file to parasolid?
If it's not too complex, I can help you.
on the stl you have to model the part and then carry it in parasolid.
Can you post the file?
If you can't, send me your references in private.
