conversion together
very interesting everything!!! !
Thank you so much!!
I'll do some short tests and maybe I'll ask a few questions in case of doubt!
Thank you ;-)
the small assembly that posted stefanobruno and fitting it according to the method you described.
Don't worry, I have to start another one soon. I'll take a look at it.
@eugenesis, ti sei salvato!
@eugenesis, if it works as you say, I'll have a beer butala.
Good morning to all, good morning eugenesis. In my way of working I find myself quite in line with what you said. But I also encounter difficulties, so I certainly mistake something!! The replacement part is heavier than the original part, right? And yet he has less intellectual information. in distinct base therefore lack information. in substitution of parts often relationships become invalid. I don't list all the problems, but I'm going to dilute a lot. I ask you an eugenesis courtesy. known a certain skill on his part with inventor, it would be so kind to point out to me the correct way from the creation of the individual parts to the conclusion of the Father together, i.e. project concluded.
Thank you very much in advance.
p.s. pdf 3d, it puts us too much to save it! !
With my method, there is no question of relations and the difference does not change at all with the level of detail.
Yeah, you're right. sin that in the level of detail there is the command "interrupt link with the basic component" (as in derivative assemblies) otherwise would be perfect.
..you'll be joking... if you open the replacement ipt file alone (it's a normal derivative set..) , do sopprimi or interrupt the link ,
or save your ipt with another name and remake a new level of detail --> new replacement --> select file parts
If that's what you're looking for!!
Ostrika, it's true. But then it's fine.
Thank you very much
