convert an ellipse entity to polylinea
  • Thread starter Thread starter joe
joe
Good morning
attach a dwg where the design profile must be converted into a single polyline
the object in red is an ellipse: Could you suggest how to convert everything into a single polyline?
underline that recreating the ellipse above the existing object (using the variable pepse=1) accuracy is not the desired one; the piece must be cut to the bone
If you can redesign it erase what you did.
set the pellepse variable to 1 and redesign the ellipse. this time you will no longer have an ellipse entity but a 2d polylinea
