convert or open with other .3dm sw files?
  • Thread starter Thread starter fra.c
fra.c
I was sent a 3d file with .3dm extension, extension that I didn't know exactly. sw I own and use are archicad and autocad but with both I couldn't open it. I searched on the net but I didn't find anything, someone has the solution?
But with the programs I have, I can't do anything?
In practice it is a structural part that I should add to a 3d in archicad that I have already completed. ..I would only have to insert this part made in .3dm
who gave it to you had to export differently, in acis sat to use solids in autocad. there should be a plugin for autocad that mporta i 3dm, but we are boss, it is commercial and you should or buy it, and it does not cost little, or download the trial, so much so that you download the trials of the aforementioned sw, open the file and expose it to acis sat to import it in autocad, I would prefer rhino no know if moi exports to sat.
the latest version of autocad, 2012 should import 3dm files natively, if you have to update this is the occasone.
for archicad I don't know, take into account that the oggets must always be solid, not mesh or faceted.
...the latest version of autocad, 2012 should import 3dm files natively, if you have to update this is the occasone... .
Yes, in fact, with 2012 they also added that type of file in the importable ones.
interesting. . .
Yes, with the 2012 version of autocad to the autodesk seems to have changed "politics" of import files. Now it matters not only rhino files, but also those of pro, catia, solidworks, nx, parasolid, as well as iges and step.
I can contact who did the file and tell him to save it in sat acis. but directly in dwg you can't?
cmq at the end I need to import it into archicad and I hope that having a dwg (solid) I can do it because that is the final purpose. Does anyone have a guide or suggestions in case?
in fact it is the shortest road, rhino also saves in acis.sat...:finger:
spaceclaim can open the 3dm files and, after editing them, can fix them in 3dm to reopen them in rhino.
they sent me the file to dwg but I can't open it. tells me file created with a no component recognized by autodesk. What do I do? ? ? ?
in acis tells me he can't save
send it to dxf...can be a solution! ! ! ! ! ! !
