convert to a single solid together
  • Thread starter Thread starter alex64
alex64
hello to all
I wanted to know if anyone knows a way, with nx7.5, to create a unique .prt starting from a set.
in practice to realize a unique part by shortening all the components of a set.
I tried through parasolid, but without result.
hello to all
load the axieme, and import into the active part file all you need with the wave geometry linker.
thanks for the information.
In fact, after opening the discussion, I had a similar thing in mind.
I did so:
I created a new file without contents that I inserted in the axieme, I activated the file and I connected everything with wave geometry linker, so I deleted all files that make up the axieme, at that point all links stop and the resulting file is a group of broken links that no longer has any relationship with the original axieme.
I did so:
without creating a new file you could have done it in the axieme itself.
One thing escapes me: why does parasolid export not work?
in parasolid works, but I do not solve the problem of the single solid body, in the sense that when I convert it back into prt all the multibody that make up the original axieme is generated.
I do not know if there is at this point some way to "solidify" at the time of conversion, boolean type or similar.
about creating the "white" file, it is true, you can do it directly inside the axieme with creates component.
you could use the monolithic jt
hello to all
symptom/problem
how can you flatten an assembly?
solution/workaround
open the assembly and select --> file --> export --> part --> set part
specification to new --> specify part --> assign a name and location --> set
object selection scope to all objects --> select components --> set feature
parameters and expression transfer mode as needed --> ok.
Also the procedure proposed by "user nx" is very valid, in fact I think it is the most logical way, I tried and in fact create a prt, with only solids disconnected from the assieme father.
in practice it can be said that there is in nx a command dedicated to this purpose:tongue:
thanks to all for the contribution.
alessandro
