convert to spline
  • Thread starter Thread starter blubossa
blubossa
I have a sketch formed by lines and arches and I would like to turn it into spline to be able to use the function "repetition guided to the curve"....... is it possible to convert the sketch?
you don't need a spline. she you have a sketch consisting of strings and lines just select it by not clicking the entities but from the feature manager, so the sketch is selected everything.
If you just need a part of the sketch... I can't think of anything else except to get a new one back by converting part of the entities below
to select only some elements of a sketch you can use the multi-selection in selection manager.
to "transform" a sketch of multiple entities in a spline you must use the command of "optimise the spline".
x marcof,
I tried to follow your advice but it doesn't work.
x re_solidworks
I can't find the command.... .
I attach the example file..........
