meccanicamg
Here we are with a new question.
I have a parallel axle reducer with my special design design design.
input 300kw-1200rpm rotation in both ways.
After calculations of the negative natural thermal dissipation, I decided to mount on the axis fast a nylon fan type faet ...the last of the page.
I mounted a square sheet metal housing with perforated mesh.
Is there any relationship between the various distances indicated on the drawing?
Should I put the fan close to the net? the diameter of the air passage hole which diameter must have? bigger... smaller?
Is there any relationship between the various distances indicated on the drawing?Should I put the fan close to the net? the diameter of the air passage hole which diameter must have? bigger... smaller?
