coordinate table processing
TECNOMODEL
Good morning.
I would need to create a table containing the coordinates of a set of points that define some work to be done on the working center.
Since the component needs a number of step-by-step development, it would be very useful for the table to be "legated" to the sketch that defines the workmanship and to be updated automatically when the sketch is changed.
Is there any way to do something like that in inventor?
thanks and good work
Are the coordinates calculated or imposed on you?
If they are set, you can create an excel table with the various data.
when you model the part, connect the excel file and call back the various parameters and when you make the table insert a table also tied to the excel file.
if the coordinates are calculated the situation is a little more complex.
I would like the coordinates to come from a set of points I'm going to define.
the points in question are nothing but the vertices of strings and lines that make up the profile to work.
in the cnc program, these coordinates and the radius or linear shift to reach the point.
What version do you use of inventor?
I ask you why I have 2015, so if you have a previous version you will not read the file I would like to post as an example
It's a very simple example.
the plate has 3 arches, each of which has specified:
milling diameter - point 1 x - point 1 y - point 2 x - point 2 y - radius - depth
the xs and y of all arches are taken from a zero piece in the bottom left of the plate.
all piloted and editable by the excel table.
changes the measurements and coordinates in the cells, saves the excel file and updates in inventor.
complete the answer because yesterday I posted it quickly.
the example is very trivial, but still requires a moment of preparation. preparing such a thing takes some time, but the next flexibility is worth it.
what I have done is very simple, and you could do much better, especially using ilogic, and setting the excel table and the paraqmeters more neatly.
But I think that once you set up properly according to the needs could be the solution to what you are looking for. You just have to do some initial practice and study a little.
thanks ilario,
I would say that the road is the right one. I just need to understand how to connect the parameters, from the online guide I'm struggling a lot to understand something.
indicates commands I can't find, so I still don't know where to look for parameters. or better, all the parameters I find them but I can not only select those related to a specific processing. in the midst of all others it is difficult to orientate.
Also the link/export is not clear, I do not understand if it is my problem or the guide is written badly.
if you have any suggestions on where to find tutorials or other on the topic would be very useful.
Good morning.
Hello everyone
This is very important to me too, but I am a total fan of inventor and from the explanation I can't direct myself.
I have the 2013 version so I can't see the example posted.
Can you help me somehow?
Can someone post an example in inventor 2013 even minimalist?
Thank you
I can't post in 2013.
I solved by inserting points into the model, then in the table I include points and when I insert the holes table select the same.
This way I have the coordinates to be transferred to the car.
I don't understand anything.
If I create a sketch with points in the model then when I go to the table I do not see them, even if I put the visible sketch, at the table I do not see the sketch function in the browser to be able to activate.
if instead I do the points in a sketch of the putting into the table the command table coordinate holes does not recognize them.
I'm at the starting point.
the points you have to insert in the part, in the 3d tab you find the command.
as if you put in a work plan or a board.
when you put on the table on the active view geometries of work and recognize them as entity to which to attach the table.
Okay, this is it.
I tried and it works perfectly, just what I was looking for.
Actually on the table does not allow me to select active working geometries, but I can select the points from the function tree and activate "includ", in this way they are visible and selectable.
Thank you very much:
