coordinates elements revit
  • Thread starter Thread starter s.rostagno
s.rostagno
Good to all,
would you tell me how to extract the coordinates of the top elements inserted in a revit project?
Moreover, how to extract the rotation angle of the element regarding the origin of the project?
to which pro?
However I doubt you can do it with revit; evil that go out in dwg and in autocad extract what you want.
Maybe with dynamo...
Yes, with dynamo you do also quickly. in the example below I extrapolated the summits of the soles, written then in csv.
always depends on what you want to get and what purpose
Thank you, with dynamo I had extracted the coordinates of the center of gravity, but I had not seen the knot for the summits.
mainly what I would like to do as revit is to get the moments of inertia, area of the section, rotation of the element respect the origin of the project, form of the section. I have seen that for the pillars it is possible to choose a form of section and automatically create the geometric parameters I need, empty to fill. so I was not able to extract this information I was thinking of getting the forms of the sections through the coordinates of the vertices. I also thought about extracting the dwg though I wanted to understand if it is possible directly to work on revit or dynamo.
