copy and move commands do not work
  • Thread starter Thread starter ritonbert
ritonbert
Good evening.
Today I happen to have an abnormal thing during the use of autocad lt.
after a short interruption (and until that moment everything worked), I resumed working on the open file and found some anomalies.
I had to move a line and I used the "seat" command and after entering the measure... the line disappeared.
I tried again and any design line I wanted to move... disappeared.
I tried to copy it... but she also disappeared after typing the measure.
Is it possible that he typed some inadvertent key?
Can anyone help me?
Did you zoom extensions?
Did you do a search for the line to check that it didn't go out? (it is enough to force the color by giving it a particular and qunidi to do a quick search with that determined color)
look that with that two information on the cross you have put can be success of everything
No... I tried to do what you told me but I'm not there.
the anomaly is that until before the break everything worked and then nothing.
selecting the line and typing the measure disappears the line ... while before it did not.
I'm sorry if I can't explain myself better, but that's what I found.
also on a new file?
Did you make a drawing recovery?
even from a new file happens this.
I tried to make even recover, but nothing.
on the other computer we have on the net, it works well on that file.
So it's likely that I've touched some key that doesn't make me run the command anymore.
It's a big problem and I don't want to reinstall the program.
thank you for your answer
This makes no sense because if the line doesn't work, don't disappearbeb but staybnbe where you see it.
did you test the search? if it is a problem even on new files is easier; draw a line, move it and do the quick search.
an entity to disappear must be erased specially.
if you say how you do operations (from icon, keyboard, command line...) maybe you can narrow the field
I solved... I had disabled the numeric keypad inadvertently and then when I typed the numbers automatically the lines disappeared.
reactivating the keypad, everything works.
I didn't realize I lazyed num block and working automatically for habit I couldn't understand why.
thank you for your answers.
Good day
then if you entered a number with decimals by pressing the point of fact you do a erase entity.
for the future;: By reading in the command line or pressing f2 you can see the history of operations.
even if I don't understand the procedure you were doing.
I made a proof that I describe:
design a line
launch the command moves (any way)
select the starting point
type a digit with decimals with the num block disabled
nothing happens (because the only action accepted or the confirmation* or cancellation)
*if you give confirmation the entity moves as far as I moved the cursor but you do not delete
Could you explain the procedure? so that succeeding in understanding how it happened can help you understand and define future answers and my curiosity obviously
design a line
Of course I'll explain!
as you described:
design a line
before sending
and the line that should move... cancels and disappears!
reactivating the num block and remaking the process ... the line moves normally
anyway thanks for your collaboration
before sending
And that seems strange to me. because if you activate the command the action deletes does not work.
instead doing some tests I noticed, but I would not put it between the certainties, that giving the command moves and, selected the first point, giving sending without inserting values (as happens with the block num disinserito) the line moves of the distance compared to the 0.0 (eg select the point that is located to x50,y67, after the move will be to x100,y134, if I remake ottengo x200,y268).
so if you happen to have a small line very far from zero to subsequent shift it goes so off screen to be invisible. in this case the quick search escape every doubt.
This is not to question what you claim about deletion, but to report my feedback
