copy beam processing
  • Thread starter Thread starter GianniM
GianniM
I use the chassis generator and I happen to have to repeat the same processing on the beam ends having the same section. for example holes and carvings.
Is there a way to copy the whole workmanship and copy it from one beam to another without having to always do all over again?
ok, stop using the chassis generator.:wink:
the problem now how is it resolved?
since the length of the pieces is not always equal, and that they can have other jobs so I can't use the same part several times, what do I do?
It is not the same part, so you have to create other parts.
to the limit, if it is a problem of lengths that vary, you can make an ipart..
If processing is always the same you can't create a ifeature?
I don't think that's a convenient solution.
make the case of having 290 beams of the same profile but of 5 different lengths. each beam has 40 processing, meaning that each processing is 1 hole or 1 carving.
on each beam 10 or 20 processes can be in common, but others are not. for this also ifeture does not solve much.
ciauz
be' for 290 pieces can be worth making an ipart with all the work and odds of the case
Um, 20 pieces, that's "listenly" faster...
from the description probably the quickest thing is to take the 20 separate parts and............ to the maximum if cutting processes have recurring complex shapes you can make them as ifeature or alternatively crude simply as blocks and copy-paste
