siriokid
I ask you an immense help:
for my aerophotogrammetric reliefs my procedure is this:
1. I extract from the photocan software a set of 3d points that have therefore coordinates x, y and z;
2. amount such dxf in autocad;
3. I create a block (for example a circle with a cross) with center in one of these points and then placed in space;
4. I attribute to this block the attribute position by selecting only the coordinate z and attribute the label "quote" to it;
5. manually copy such block on the model at each point (see step 1);
6. through express tools I explore the attribute;
7. I use the flatten command to break down at zero altitude all points and attributes.
8. at this point I have the set of points in 2d (all at altitude 0) but indicated next to each its quota z (altimetrica) previous;
My need is to have an automatic procedure that replaces and accelerates step 5 where instead I use a lot of time to copy the block on each point if these are obviously numerous.
in practice my idea is to have a command that allows me to copy the selected block (to which is connected for example the position attribute) to a multiple selection of equal or similar objects, in my case all the point objects of the design or even better all the point objects that are on a specific layer.
Who can help me?
Thank you very much.
alessandro
Who can help me?
alessandro
