copy fx parameters in multiple ipt/iam at a time
MARCOC
I'm sorry
with the design-assistant you can copy iproperties from a n file.. .
I ask you and can do the same with the parameters?? with design-assistant you can't...is there another way? ? ?
the parameters you can connect them between files;
put the export check, you can also derive or connect as you want
directly from the parameters window (fx)
Maybe I've been in pain... I have a file named pippo to the inside I have a custom parameter "a"..io I would like to copy the same parameter "a" in n ipt/iam file automatically...but the parameter should not be connected to another file.. .exactly as it happens for iproperties used design assistanct...which allows me from a source file to copy the same iproperties in n files selected by a list. .
I hope I've been a little clearer
ahh excuse , you just need the parameter name , do not manage the value .. ok
the thing that comes to mind is that you could create user parameters with the desired name
directly in the template and then call it back to the model parameters from time to time.
my problem and that I receive files of different users and I have to copy within the parameters that serve me... and I have to pass them one by one...
in my template I already have them, and what I use as master...from I would want them to automatically copy in other files
. Perhaps it would take some macro vba or similar .. but I see it hard if everyone creates and renames to pleasure the various things
without a unique logical criterion
Let me be vba... in the post before you wrote me call back from time to time... What do you mean? when put in the templates how do I pass it to another file? ? ?
try exporting parameters to a management file--> parameters fx --> export to xml and create the templates,
on other file management --> parameters fx --> impora xml and so should work.
