copy of a view from a drawing to another
  • Thread starter Thread starter Fabietto
Fabietto
Good evening to all,
I created a design of a set and its components by managing the table of the individual components through the simplified representations of the axieme.
Now I need to create individual design files of the individual parts to be facilitated when I make a copy save.
exists a method to copy the views of the individual parts on another design and redefine the reference model from the sempl rapp to the single part?
I tried on the properties of the general view, but it only allows me to change the rapp simpl, but not to change the model to which the view refers.
do not tell me that I have to remake the drawings for each part.. .
I use wf2.
thanks for every possible help.
fabio
if you have set the correct parameter when saving a copy of a part or together it automatically saves the copy of the relevant design for which you should already find it. if instead the parameter "rename_drawings_with_object" was not set correctly (both) for copies already made you have to remake the designs or copies.
aminati
p.s. should be independent of the version used!
Thank you,
that already is set and works.
But if I have the design of a part within a drawing of together, and the part has not been added to the drawing, but well put into the table through rapp simpl, if I want to create a copy of the part and its single design I can not because if I do the saving copy of the axieme you copy all the assemblies and all the drawing or drawings associated with the axieme.
in poor words:
I have a set with different parts, I created simpl rapp for each part, I created a design that has as default the axieme, inside the same drawing together I created the tables for the individual parts, but not inserting the model of the part in the drawing,
but managing the view through rapp simpl.
But now I want to separate the drawings part by side without making more reference to the axieme, but to the single part.
I hope I didn't mess with you.
fabio
you do not work like that, you have to make a drawing for each part.
If you have a set with 9,600 components what do you do... 9,600 simplified representations?
what you would like to do is replace the model of assembly represented in one or more views with a part model.
I think it's something you can't do, because replacement can only happen between models of the same family.
You can try something before you have to remake the drawings, but I don't know if it works.
at the table add the model of the part, create the same views you have made for rappr.simpl., move the quotas and annotations on the new views.
If this lets you do it, delete the old views and remove from the design the model of the axieme.
@maxopus: you are perfectly right, youth mistakes, but unfortunately now done damage is...
@cletus: I have already tried this solution, it allows me to copy only the notes, but not the quotas unfortunately.. and also making properties of the view, going to the voice displays states, allows me to change only the rapp simpl of the view, but not to select another model inserted in the drawing.. .
So I have to put my soul in peace and make the drawings again. .
Following the concept of drawings, even together then I do not want to tie the modeling of parts to sketch of assemblies, otherwise if I want to reuse a part outside the axieme I am screwed.
If I want to create a similar part, not linked to the axieme, it becomes impossible unless I copy the whole axieme. .
You can open the part and save a copy.
when you open the copy, replace the references that connect it to the axieme, with internal references to the part (for example with the starting reference plans).
