proxinge
I'm putting on the table a relief made with celerimetric method and I have to extract sections and prospects from the wire pattern of iron.
to do this, since the 2002 release, I use two files simultaneously: the first with the wireframe model with ucs aligned to the view I have to extract (section or prospectus) and the second with ucs=wcs where I take the lines copied from the first files on the original coordinates. deleting the z on the second files I have the required view with respect to the coordinates and above all always georeferentiated (through the transformation of coordinates between wcs and personal ucs).
I discovered today that, both with rel 2015 and 2014, copying entities (usually lines) from a files with a custom ucs to another files with ucs=wcs I no longer have the respect of coordinates or pasting on the original coordinates the entities go where they want.
if I use the good old autocad2011 instead everything straight.
Any ideas? (some variable maybe? )
