copy properties
  • Thread starter Thread starter Filo
Filo
I've just been through solid, so maybe the question is stupid, but after half an hour of attempts I surrendered.
is it possible to copy the properties of one object and paste them on another?
Specifically it is possible to copy the properties of one joint (mode) on another?
Thank you very much
inventor 2010
Thank you very much
inventor 2010
if by property you mean iproperties then you have to use design assistant if you mean model creation parameters, then I don't know.
if by property you mean iproperties then you have to use design assistant. .
Thanks, I didn't know, for other things it can be useful to me.
...if you mean model creation parameters, then I don't know.
Yes, specifically in dynamic simulation I have a set of springs all the same and I would not like to, for next time, insert all the deficiencies of spring one by one.
then you can make an ipart of the spring, all sizes are handled by a table. each row of the table corresponds to a spring and you can add as many as you want. then you generate files (dx mouse on the part that interests you, in the tree) and create the (derived) part that you use in your assemblies.
I don't know if that's what you were looking for.
