IBWorks
Good morning to all, is there a command that upgrades the properties of a table view, copying it from another view? For example, if I mistakenly put on the table all the views with hidden lines dotted visible and then in the end they wanted me hidden, now as now, I go into the properties of each view and the edit (but takes away a lot of time). I wondered if there was the system to change a single view and then with a command select the other views and make the same changes (a bit like copying quota attributes). Thank you.
