copy tabled from one sheet to another
  • Thread starter Thread starter michelix
michelix
I have to translate my designs into Polish and I would not like to create another drw pointing on the same asm or prt, I would like to add a sheet by copying the views, notes and quotas I have already made, but I do not find a command to do so... Can anyone help me?
tnx a lot
I need the same thing too!
Is there a way to copy everything to another sheet I create?
if I didn't get it wrong:
1- create a new drawing that points to the part/assembly that interests you;
2- insert -> shared date and go get the drw that interests you.
on the drawing you create a second sheet that is the copy of the original. delete the first sheet and the game is done.
Hello alex, thank you in the meantime of the reply.
I solved but I add another step:
Before doing the procedure indicated by alex, you must first save a couple of the file and import the same in the drawing. automatically you create a new sheet.
in the wildfire 5 they entered the ''setting and copy' option.
popping up ''creates a copy'', automatically creates an identical copy of the current sheet if you do a thousand steps.
