Gian_Attila
Good morning to all, after different time I am here again to ask for help!
I tried to search but I didn't find anything, maybe I didn't use the right terms.. .
My need is this: I should copy the value of the attributes of a block into one multidirector to another. I tried to bypass the problem by exploding the director and copying from block to block, always through lisp, I then stuck at the time to recreate the multidirector. ...
someone has a direct solution to copy from nested block to nested attributes (faster method) otherwise I also settle to recreate the mleader at the end.
thanks for the support
