copy the whole line from the property name.but I have to copy only those in the value field and not select them as I do?
Well...then it seems that you cannot do this
Wait. .I should only copy the values of what remains unchanged but I would do it all together
if the properties are scattered do first to rewrite them by hand. If you want some proposed property "values" you need to use "tab builder", make yourself a compilation card and during the configuration of tab builder you can put some suggested answers. to do so you have to enter the drop-down menu leaving manual writing possible.Wait. .
but then copy with ctrl only the lines you need.. or do I still not understand? ?
Mar
