ansyolitico
I followed your advice to correct satellites with x=0.1845
I also played heavily with head(-0.2) and blacklash(0.06) parameters for satellite,
solar blacklash(0.06),
crown head(0.4) blacklash(-0.05) clearence (0) (of which I have doubts about this last parameter if it is correct)
and I performed a further truncature of the tooth extruding a circle of diameter 44.8 (I had to reason on the contrary being the crown a negative).... put in print, assembled, turns very well
because of the absurd values of head and blacklash are due to the fact that by printing you increase by about a tenth profile, in practice if you print an outside circle 10 and inside 5 the real values will be 10,2 and 5,2....and this worries me a little for the relationships
It's not a university project but an extra thing of mine, because I think until you do, you can study how many books you want, but you'll always have partial knowledge of things.
I have no idea how it can be done to touch the parameters of the gear profile in 2d... I think you have to go directly to touch the code in python to do so... .
I have read several times in your interventions that you mention those books... you don't know what I want to find a copy... but I know that they are introvabile... an alternative of the same modern level?
I thank you so much for your availability and advice
