pd_frankie
Good morning, everyone.
have any of you found yourself in a situation similar to this?
I have to create an electrical picture to install outdoors, even in coastal areas; for question of costs I have to make it in aluminum sheet peraluman 5754 thickness 2mm with thread inserts m4 in stainless steel 316, all then painted in polyester powders. 316 stainless steel screws will be used on the inserts. we must guarantee 5 years on the product.
galvanic corrosion between insert and aluminum sheet should be prevented from painting; while between insert and screw should be no problem as of the same material. I'm not wrong, am I?
and if the inserts were in normal galvanized steel?
thanks in advance for sharing your experiences.
