corrosion coil heat exchanger
  • Thread starter Thread starter SOLID
this is the plan of the serpentine to be realized. . .serpentina.webpthe current are made by welding head bar 6 meters.
it is essential to contact the galvanized to discuss with them the problem (also depends on the size of their galvanizing tanks).
so "nose" I don't see it impossible, maybe you will have to give a minimum of "pendence" to the horizontal traits to avoid the accumulation of zinc.
Another problem is the temperature of the bathroom, very high, which could deform the artifact (although in such an application I do not see it so problematic).
Besides the serpentine there is also the support frame which consists of profiles arranged vertically and welded to the right sides and left of the serpentine, should be enough to prevent all curves reopen. . .
