corrugated cover - variable section beams
  • Thread starter Thread starter kubbah
kubbah
Hello. I would like if possible to have advice on how to make a corrugated cover, which follows a curved surface (different sections) and in addition the elements (the beams) we have variable sections. . .
is it possible to do it with the facade continuous to have also parameters or do I have to make every beam one by one with the conceptual masses?
I attach the image
Thank you very much in advance
I attach the image
my question is: but then a similar structure who calculates it? ?
if you can model you can also calculate but is another speech
If we had to do it by hand we could go for approximations to look at the weight of the beam and see the moments that are generated, then ditribute the material in the way to cover the moments.. but as I said it is another speech.. we are in the revit section and not in the version sap/robot .
thanks the same for the interest
It was just a curiosity... .
anyway for what I can see and imagine. ..mass and adaptive components. but it is a nice mess with similar forms
:finger: I think the only ones that can give you a clear and exhaustive answer are the engineers of the study of f.o ghery:biggrin:
It seems to me a structure a little out of revit's patterns, but it will be interesting to see how you're going to manage it.
Good job
