corruption file
TECNOMODEL
for the second time in a few days a file of inventor has been corrupted.
this time it is a feature, if I try to change it both in the processing and in the sketch, the application is blocked.
the previous time a ray feature created the crash of the application to the end-part mark movement.
both files were created with old inventor releases and contain sketches glued by autocad.
I don't understand if they're problems in the rescue phase, if they come from autocad sketches or something.
It's becoming a problem, I'm constantly stuck with work and risk losing a big slice of what's done.
suggestions?
suggestions?
I always refused to create anything from imported sketches, even when I worked with solidworks.
doing so I lose a little more time but gain us in stability.
I fully agree.
the problem is that I work on a project started by others, which by the way are no longer in the company.
I'm trying to boat me without having to do it all over again, so what I can keep him.
