cosmetic axis line inv2010
  • Thread starter Thread starter ckaal
ckaal
I am trying to exploit the new command that should create the diamond in the sheets.
in the online guide there is a beautiful example showing the effect of the command both on the folded piece and on the flat model.
It's been a while since I try but I get a partial result, that is only on the flat model (which you could do before manually in the table).
how do you display the diamond on the folded piece?
I have to do a commercial datasheet where I want to insert a rendering of the piece and I would like to be visible also the diamantatura that actually is present on the real piece but I can't.
Can you please explain how you do it?
Mar
I know that cosmetic axle lines are only for the flat model, there is no way to do it in the folded one.
Finally an answer.
Thank you diegus.
we have come to the same conclusion, but if we are right, the guide of inventor 2010 draws in deceit because in the model 3d you see clearly the lines of diamantatura.
Thank you, good to make.
Bye.
