hi stefano, go to management views, sections, click dx on the section you want to edit, redefine, sampling, spacing, value. Then you put the value you want.
I see you haven't submitted yet since this is your first message... you can do it this section of the forum.
Hi calacc,
Thanks for the answer.
Sorry, but maybe I put the question wrong.
I did not write how to redefine the field on a view in section 2d,
but how to redefine a sample made on a surface of a solid as cosmetic and redefine the spacing of the same.
In essence I give a text on a surface of a solid, as cosmetic, and inflate the spacing of the sampling but only on solid 3d.
I hope I've been clear.
stefano antonio
I tried to read you several times, but I still couldn't understand. maybe because you talk about a function that from wf 5 (the first version I used) then disappeared. Could you post the file? Perhaps by editing your function I can understand what it is?
Hello mad76,
I'll get you the file.
In practice it is a cube where on a face I wrote, in cosmetic mode, letters a b c.
Now I should put the sample in every letter.
This is just an example, in reality I have to make some writings on a plane, and put in space,
because visually on the model must result with the full body of each letter.
I don't think there's a way. config.pro's options do not seem to suggest anything. I would do a 0.1 mm high extrusion from font3d, if you are on a flat surface. Usually for fully filled body writings it is okay if you do not alter the weight of the model.
