cacciatorino
It's something I use a lot. put that you have a component in an assembly and want to make it a new one derived from this.Thanks for the answer, I would make simple mechanical parts.
to the maximum components that are realized through fusion/pressofusion...the features that I will use will be 99.999% extrusion and revolution.
What would "replace part with copy"?
I never opened solidedge
the normal flow would open the part, save it with the new name, and then return to the assembly and replace it. with that command do everything without leaving the assembly.
