therefore, the walls must have a minimum thickness (in mating area along the section plane) of 4mm;
There would be no problem with extending outwards (there are no constraints related to other perimeter geometries) and not even getting 1.5mm .
for the holes I will do as you say: I can only see the ones from 40mm in diameter, the rest octuro and do the next processing
4-5 mm of overmetal should be added to the ideal thickness for the wall? on both sides?
on both sides
I think we have to work both faces
for the deform you have to use "opture"Referring to the attached pdf
is said to increase the measure
Thank you very much
