cost systems
  • Thread starter Thread starter Paulì_zx
Paulì_zx
hi guys, I wanted to ask you a general question about the costs of the cads currently most used around, I think about catia, nx, solid works, solid edge, proe, inventor, rhinoceros, think3 and others that I may not even know.
Of course I would like to know a gross figure, nothing specific.
to list the average-end cads turn on 6-7000 euros (parlando di se, swx, etc), those of top band (catia, ug) starting from 10.000, and to climb according to the modules chosen.
separate speech for pro/e, whose basic version starts from about 6000 but then is strongly scalable upwards.
However of these times I hear about admirable discounts compared to official lists.
rhino costs less than a thousand euros, the others from six thousand up.... :
we posted at the same time. ..however I had seen that even nx had a basic version around six thousand.
...another information. ..the purchase of the license is personal, ie if I more than one computer on which to want to run these programs... how does it work? should I buy more licenses?
you have so many licenses for how many uses contemporanee You want to have it.
I'll explain better.
if you have two pcs (e.g. fixed and portable) but you only use one at a time, you just need a license, which you will move from time to time on the pc you are using at that time. If you have two pcs and use one of you and the other your partner, both at the same time, then you need two licenses.
